Encoder parity bit errors
dmbartender
Jul 2008
Germany
40
Hi guys. I've got a machine using B&R as a positioning control, with Bosch Rexroth motors. In our plant the machine worked quite well, but at the installation I keep getting encoder errors on a couple of axes as soon as I switch the servo control on. It says there's a parity bit error. Sometimes this goes away for a while, but it always comes back, and it's always on the same axes.
I checked the wiring and connection of the encoder, and it seems to be fine. The errors occur on the motors that have the longest cable lengths, so I assume that EMF has something to do with it.
Is there anything I can do to remedy this?
I additionally grounded the shielding at the drive side. I was thinking of doing it at the motor side too, but am not sure how to do that
the cable has a shielding, which is folded backwards onto the cable, and this has a band of copper on it. This is affixed to the connector. I attached a ground wire to where the shielding abuts the connector.
Sorry in advance for the long post, but this requires a little back story. I work in a facility with a couple hundred VFDs Most are in a web...
234
I have an application using an incremental encoder and then I convert it to degree (0-360) using calculation program. For a while, the calculation...
320
Hi everyone, This is my first time posting, so please forgive any omissions or mistakes. I am attempting to control the velocity of a stepper...
18
1,033
Dears, i am trying to change the series of encoder from A to B, but the program do not has this option (Rslogix5000, 20.06 the old encoder was...
214
Hi all, I am working with an incremental encoder (ABZ signals, 360 ppr (so 1440 counts per rev)) to replace the existing "manual" encoder wheel I...
51
2,628
