leitmotif
Press setup is just about as dangerous as maintenance - normal safeties are bypassed in both cases. In addition setup is done with the dies not fully aligned and dies can be damaged.
Instead of all this electric control to "manually" move the piston what if you put two valves in parallel with the "normal ie electric controlled" valve. One would be "high speed" the other would be "creep" with an adjustible needle which would allow them to creep into the position they want. These would be in locked box with only supervisor or setup guy with the key. Granted -- more valves fittings to leak etc etc and you will NEVER get them in the right position for all tasks but I think a little more foolproof.
I really like the pendant idea - that way the guy has the controls right there and his eyeball focused where he wants it.
IF I understand correct you are using multiple position push button switch. My concern here is that like a crane pendant the button can be bumped (like when you screw up and let go of the pendant and it hits whatever). A guard over the button would prevent this of course.
What about two buttons. Press button one which activates time delay THEN press button two to activate - other hand would be free to dial in the encoder -- as long as both buttons are pressed with the "delay time frame" then it would activate.
I guess when it comes to press setup you have to trust your people to understand the dangers and to know what they are doing.
I would not want to screw up a die and have to pay for it - there goes at least a year salary.
Dan Bentler
Dan Bentler
