Encoder/ PLC
bigdan5428
Nov 2010
Evansville, IN
Does anyone know of any light duty encoders, that can be directly wired to 8 bits on an input card. I don't care if it counts binary or grey code, I can use either one. I need a simple setup, with no amplifier. After searching the internet, the only thing I can find is a 3 wire output that only comes on for a few microseconds. Is there such a thing of an encoder that has 8 outputs to be wired directly to an input card.
Hi Folks. Has anyone used an SEW EI7C encoder with an S71200 PLC? If yes, how is it done? I use this same encoder in EI76 mode with a...
272
Hi y'all. I'm kind of used to program in TIA portal but not in simatic manager. So now I have a little problem at a client of mine. sometimes...
554
I am working with this module xbf-hd02a from LS plc. I want to hold the encoder count in case of power failure, for this I am setting the present...
706
I'm a beginner and not sure what to do. I want to monitor the rotation of a motor. I have a FX3U PLC and a RI58-O/100 encoder available. The...
1,429
Hi, I am trying to learn how to use my encoder with my PLC. I recently got a high-speed counter module (H0-CTRIO2) for my DirectLogic05 PLC. I...
2,239
