encoder to HSCE help....
tech-1452
Jul 2009
wapakoneta
I am currently using an encoder with only a single channel (A). I am using a HSCE card in slot 1 to create my RPM sampling off of I:1.3 and multipling by .6. This all works but the encoder I am using has been discontinued by Allen Bradley. The only encoders we carry at the plant have A, B, & Z. I tried using only channel A but get a way off RPM. any help. I was told I have to use what we have in the plan.
You have not mentioned how many pulses per revolution the encoders are. Not all encoders have the same number of pulses per revolution. The encoder you are trying to use should be fine for the application. The model number of the encoders often contain a number that represents the 'PPR' of the encoder. Who are the manufacturers, and what are the model numbers
I am currently using an encoder with only a single channel (A). I am using a HSCE card in slot 1 to create my RPM sampling off of I:1.3 and...
1,436
Hi; I have an ELCIS brand encoder 50pulses 8-24VDC which i want to use at a machine. I have SLC-5/05 and 1746-HSCE high speed counter module to...
1,059
I am rebuilding a line with 2 conveyor sections, that the process speed is calculated from a rate signal from 2 high-speed counter modules. The...
1,502
How do I keep track of the counts for this encoder in programming. I am using logics 500. The encoder PPR is 1000.
2,913
Hi Everyone, I have searched the previous threads, but could not find an answer to my problem. My process uses feed rolls to meter out product...
5,275
