encoder to HSCE help....
tech-1452
Jul 2009
wapakoneta
I am currently using an encoder with only a single channel (A). I am using a HSCE card in slot 1 to create my RPM sampling off of I:1.3 and multipling by .6. This all works but the encoder I am using has been discontinued by Allen Bradley. The only encoders we carry at the plant have A, B, & Z. I tried using only channel A but get a way off RPM. any help. I was told I have to use what we have in the plan.
Going just by your description, using just the A channel off the other encoder should work(unless the encoders electrical outputs are very different.) It sounds to me like the encoder has a different PPR Pulse-Per-Revolution value. Do you know what the PPR is of both of the encoders? If they are different you could re-scale your multiplier to make the RPM correct. Unless you it's a lower PPR encoder and you need the resolution.
I am currently using an encoder with only a single channel (A). I am using a HSCE card in slot 1 to create my RPM sampling off of I:1.3 and...
1,326
Hi; I have an ELCIS brand encoder 50pulses 8-24VDC which i want to use at a machine. I have SLC-5/05 and 1746-HSCE high speed counter module to...
1,057
I am rebuilding a line with 2 conveyor sections, that the process speed is calculated from a rate signal from 2 high-speed counter modules. The...
1,502
How do I keep track of the counts for this encoder in programming. I am using logics 500. The encoder PPR is 1000.
2,913
Hi Everyone, I have searched the previous threads, but could not find an answer to my problem. My process uses feed rolls to meter out product...
5,274
