Encoders and PLCs
mhmtfthnl
Nov 2003
everywhere I can go
42
Hi.We have an S7-300 PLC and also incremantal encoder.How can I connect them each other.Which programming material must I use to convert to analog value in the Simatic Manager.
Thank you.
Best regards.
There are several methods:
1, conventional is to connect them to a high speed counter card. Most PLC manufacturers design their HC cards to connect to incremental encoders, so this should be easy. Just follow the instructions and make sure the encoder is compatible with the card.
2, Connect to an ordinary PLC input card, this will only work if the encoder increments slowly. I would not reccoment this method. however,I have seen it work airly well with an absolute encoder.
3, Bus Connection, I have seen encoders for most popular busses. For an S7 300 you could get an encoder for either Profibus or ASi.
There are other methods, but the above methods are the most popular and best understood.
As for programming, standard S7 programming software will work. The values are simply transmitted to a register and this can be read directly. There is also some function blocks that can convert these, but I never found I needed to use these.
Doug
Hello I just wanted a quick and simple overveiw on how encoders work and what they are used for. And how you connect one to a plc Thanks
20
28,871
I was wondering if 5032-8IOLM12DR are suitable for encoders devices. I'm concern about the RPI and loosing encoder counts using this type of...
115
I'm thinking to have a 5032-8IOLM12DR and encoders plug in to them. I'm concern about the RPI and loosing encoder counts using this type of...
87
First time poster here so long story short i built my own trainer at work so i could toy around with various things and test things and learn...
25
2,156
Good Morning , We have a large machine with a number of shafts , and I would like to monitor those to make sure they are constantly...
2,129
