Frank,
I haven't seen anything about your C-more set-up. For example, how and where do you tell the C-More to look at V2026 for Oil Pressure, and so on?
According to the manual, you need to use the C-more Micro-Graphic Programming Software EA-MG-PGMSW, downloadable from the AutomationDirect.com site, to write your C-more program to tell the panel how to read the data and where it is located.
I think you are using the C-more Micro 3" screen. Chapter 5 of that user manual contains the System Setup. Have you gone through that?
