ENI question
Williyb
Sep 2003
35
Another question,
I've been trying to get my test bench set up with a new ENI module to a 5/04 SLC. On my office computer I can see my original 5/05 and the panelview thats runs thru a ENI out on the line. My first idea was to just set up my new IP in the same driver in Linx. But I keep getting a error code. I see the ENI module in linx but its fuzzy and the red X flashes on then off.
Do not have my ENI programmed correctly? I did see the 5/04 once when I changed my channel 0 to DH485 but I couldnt upload or download. Now after screwing around with it I can only see the ENI module in Linx. Should I set up another Ethernet driver in linx or can I just use the first one that I'm using now that is working. It was easy to set the 5/05 to Ethernet operations but this ENI module that I've never used hasnt been that easy.
I've searched this forum but didnt find anyone having the same problem. Right know I'm just trying to get the 5/04 on the Ethernet.
1500 not 5/04 but maybe it will help
Williyb,
I use the ENI for Micrologix 1500 but all I do is go online with the ENI and give it a static IP address, SubNet Mask and disable BootP and then download. I just check my test bench with the MicroLogix1500 and the channel is configured DF1 Full Duplex.
Hope this helps.
Bob O.
I tried the DF1 Full duplex but have the same occurance. I use the ENIutility program and it worked on my last one but this one is fighting me. Thanks
The latest Rockwell magazine ( I think it is called "Connections") has a good article on setting up the Net ENI module. Should be able to download at Rockwells website. Regards Alan Case
Alan I checked out the article and I have that understood. I also read up on the knowledgebase that I didnt find during my last search. But I still have a few questions that I believe the manual will answer. I tried to find the on-line user manual, even entered in the exact number 1761-UM006A-EN-P, but I guess they dont offer it on-line.
Anyone have this manual in .pdf format?
im setting up some rate screens, for some welders at work through excel i have a 503 hooked to a ethernet eni unit, i have set up the excel page...
1,672
"Hello! Good day! Excuse me, I have a question regarding the 1761-NET-ENI. RSLinx has already detected it but it's not connecting to the PLC...
146
Good afternoon guys, does anyone recommend a direct replacement part for Allen Bradley's 1761-NET-ENI devices? We have a lot of these in our plant...
1,009
Hi. I am having trouble establishing comms between an slc5/04 and panel view plus 7 via a PLX51-net-eni. The set up is: 5/04 Channel 0 DF1...
932
Hello, currently I have a micrologix 1200 (1762-L40AWAR )connected to an HMI panelview 600(2711-T6C3L1X) via the 1761-net-aic module, I want to...
1,796
