EPLAN8- Cross reference-Display
kalabdel
Feb 2015
Ontario
1,108
Hello Gentleman,
I would like to display the cross reference along with DT at the end of the interruption point in pic#2 exactly as they are displayed in pic#1 but pointing down in line with the arrow.
I tried different ways but I'm clearly missing a trick somewhere.
Thanks karlek, that worked like a charm. I spent hours and thought I tried that option but I guess I didn't. I ended up learning a lot though so it wasn't a complete waste.
Thanks again 🍻
What is Cross-reference (configurable), how is it configurable.
If I "Undock" it a few setting open up to me but the same happens with Cross-reference without the "(Configurable)" part.
In the past, we have used AB 1492 feed thru screw terminals a lot. Lead time on these with our distributor is terrible. Is there an almost...
119
In our production plant we have multiple different networks (subnets). IT dept have setup routing between them so different subnets can...
102
Is it possible to connect a PC with running WinCC Advanced or Unified to a siemens PLC such as S7-1200 across different subnets? The computers can...
91
I want to establish a Profinet network in my production plant to connect multiple devices, including a PLC, HMI, and multiple Profinet-based...
19
686
Hi all, Attached below is an example of what is happening to our existing SCADA. It seems after patching some Rockwell Software that I thought...
328
