EPROM or EEPROM for Siemens S5
Boyko
Oct 2005
26
Hello.
Could you please tell me what type of memory do I need to store the program for S5 PLCs: EPROM or EEPROM or both of them.
Which memory will do the job:
1. Memory submodule (EPROM) 8 Kbytes 6ES5 375-1LA15
or
2. Memory submodule (EEPROM) 8 Kbytes 6ES5 375-0LC31
The CPU is 102.
Thanx in advance.
either....
here's the list from the manual:
Memory submodule (EPROM) 4096 statements 6ES5 375-1LA15
Memory submodule (EPROM) 8192 statements 6ES5 375-1LA21
Memory submodule (EPROM) 16384 statements 6ES5 375-1LA41
Memory submodule (EEPROM) 1024 statements 6ES5 375-0LC11
Memory submodule (EEPROM) 2048 statements 6ES5 375-0LC21
Memory submodule (EEPROM) 4096 statements 6ES5 375-0LC31
Memory submodule (EEPROM) 8192 statements 6ES5 375-0LC41
You can only have one memory module so must choose which is best for you. The main difference is that an EPROM you need an EPROM eraser to clear the EPROM if ever you need to re-program. For an EEPROM you do not.
I did this once before but it was about 30 years ago I just tried it on a plc this morning and,when i fitted the eeprom and downloaded the...
2,181
Hello, One of my colleagues were at a plant were we have two old Siemens 314s running on identical seperate processes. He did a minor...
1,749
Hi Can anyone tell me why some siemens s5 eeprom modules have 5v written on the outside of them.Im assuming the obvious that its a 5v programming...
2,522
I recently made a change to a customer PLC (to fix an OEM mistake). The change was necessary, but I had to leave them running on prog in RAM. I...
3,916
I've been asked to look into a Siemens S5 problem. The PLC seems to have lost its program and I have a copy on EEProm but I don't know if when I...
15,168
