Siemens S5 EEPROM
mjisaacs
May 2005
Morganton, NC
66
I recently made a change to a customer PLC (to fix an OEM mistake). The change was necessary, but I had to leave them running on prog in RAM. I need to "burn" (or, as Siemens calls it "blow") the EEPROM with the new program, but I do not have a "prommer". Does anyone know anyone that can help me? I cannot trust that the customer will keep the batteries changed.
You can also burn the eeprom with the old 'brick' PG's as well if the customer has one of those knocking about. The eeprom will plug into the side of it.
Not sure if you have access to one of those?
Good hunting.
Cheers
JT :)
Good hunting.
Cheers
JT :)
No, the customer does not have one. Can anyone out there help me?
we use a stand alone Prommer from Siemens in lieu of the siemens PG. The part number from Siemens is C79451-A3449-A11. It will do the flash cards and EEPROM's. The software for it depends on what you are using it for, I know that it will work for most siemens programming software.
Cable for external prommer C79451-A3449-A11
I lost my cable for connect external prommer C79451-A3449-A11 with PC (parallel). Can I make this cable by myself and what is the connection ?
Thank you
I did this once before but it was about 30 years ago I just tried it on a plc this morning and,when i fitted the eeprom and downloaded the...
2,182
Hello, One of my colleagues were at a plant were we have two old Siemens 314s running on identical seperate processes. He did a minor...
1,749
Hi Can anyone tell me why some siemens s5 eeprom modules have 5v written on the outside of them.Im assuming the obvious that its a 5v programming...
2,523
Hello. Could you please tell me what type of memory do I need to store the program for S5 PLCs: EPROM or EEPROM or both of them. Which memory...
3,793
I've been asked to look into a Siemens S5 problem. The PLC seems to have lost its program and I have a copy on EEProm but I don't know if when I...
15,168
