Equustek DH+ to Modbus converter troubles
cardosocea
Nov 2016
Fields of corn
2,642
Hello Gents,
I'm replacing a DataLink GW1000 by an Equustek DL3500 and can't for the life of me understand what I'm doing wrong.
The original device still works when powered via USB, but the internal power supply died.
I've configured the new device with the settings from the other unit but I can't get comms or even find any troubleshooting guide to point me in the right direction.
The comms settings are all the same between units, but the AB addressing scheme is different. However, after trying every combination I can't get anywhere.
The PLC5 tells me that the addressed file doesn't exist in the node, so I assume that the node is seen on DH+, but I'm unsure of what other combination of file numbers to put in, or if perhaps the file numbers are dependent on having a successful Modbus comm link.
Anyone used this before?
Hi I am trying to get a PV+ 1000 (Ethernet) to talk to a SLC 5/04 (DH+) through a Equustek DL4500. I can setup a network on my PC easily enough...
1,563
Our plant is currently going through a DCS change to a Siemens T3000. We have been running F.A.T. at the Siemens location. The problems we are...
4,087
I have found something interesting about the DL3500 and wanted to see if anyone else has came across this. I am connecting to the DL3500 via USB...
2,405
If anybody know how to configure DL35000 DF1 to DH+, please tell me. I have four SLC500 with 5/04 processors.The PLC comunicates between them via...
7,779
Hi folks, I have a Controllogix in communication with a zigbee coordinator using Logix AIO for modbus tcp. This zigbee coordinator have 3 slaves...
96
