Error-code 8093 from SFC14
mulderm
Jun 2003
Netherlands
298
Hello,
I have a profibus network with the CPU 315-2dp and an inverter as slave from Lenze.
In the hardware configuration I have the adresses of the slave setting on I 256..259 and
O 256..259 (2 words).
Now I have programmed in OB1 the SFC14 block.
LADDR= W#16#100
RET_VAL= MW100
RECORD= P#M 100.0 BYTE 4
Now the problem is that I received code 8093 on the RET_VAL.
I have seen in the help that this mean:
No DP module IO device from wich you can read consistent data exists at the logical adress specified
in LADDR.
But the adress is 100 in HEX what´s mean 256 in dec.
When I making a VAT with PIW 256 and PIW 258 and monitoring I received the information
from the slave so I know that it´s working.
But why I received Error code 8093?
Greetings,
mulderm
not being very sure i think it may have somthing to do with configuring your profibus modul .but i think you would just want to make sure that you use consistent data cause sfc14 and 15 work with consistent data. i dont know about other modules but for example 2133 offers great variety of dp telegramm types so i believe it should not be a problem otherwise i think you just gonna have to read directly from input area without using sfc14. but could you reply if it can fix the problem cause i did not encounter such a problem i was able to read and write pzd with sfc 14 and 15 and even read and write parameters very easily.
Hi there, I'm new to plc programming and was wondering why I get this error code when I run my simulation for these temperature sensors? What I'm...
87
hello, I'm a student and for my final grade I have to repare a sepro robot. the only problem I have for now is that i have an error code 3...
51
Hi I have been knocking my head against the wall trying to figure out why these two plcs won't talk with Produced and Consumed Tags data. The...
493
Error description: "A connection could not be established in the open process of the TCP connection." Action: •Check the operation of the...
137
Hello, I'm trying to test Acopos multi using Automation Studio. Ready LED is green blinking, how can i know what error of Acopos on Automation...
146
