ET200M vs ET200 SP HA
Lc1
Jan 2014
Uk
59
Hello,
With regards to the bases of the ET200M and ET200 SP HA is there an appreciable difference in the physical footprint of the bases? From what I have seen the ET200 SP HA is taller and a little deeper but the ET200M is wider as the IO modules are around 40mm wide whereas the ET200sp HA is around 22.5mm and they both have similar channel density.
Is it enough to warrant significant attention? Has anyone came across this before?
Hello, ET200SPHA has higher IO density as AI is 16ch,DI 32ch,DO 32ch and AO 8ch in 23mm wide. The max slot you can have is 56 cards in one rack. So you can install vertically in your panel to save space. Redundant interface card with PROFINET.
I think the part that warrants significant attention is that Siemens has more or less said the S7-300 & ET200M will be phased out Oct 1, 2023, and are therefore encouraging users to switch to ET200SP HA for PCS7 applications.
I'm just trying to figure out the right method of adding a DO card to an existing rack. It's not the *next* open slot, but I have to move the AO...
557
Hi, A customer is requiring a ET200M in our control panel, I have never used them and would appreciate some help regarding if I understand it...
808
Hello friends I am about to get crazy, I am trying to connect a ET200M (Siemens) to a Prosoft card, the part number is MVI56-PDPMV1 in a...
5,114
Dear Experts, I have a question regarding the redundant S7-1500 CPU and ET200M connection. Will ET200M IOs work on a redundant S7-1500...
2,107
Hello, I have a question with regards to the ET200M remote IO base. Are the input and output modules powered from the system backplane or do the...
1,283
