Ethernet Card Comms Capacity
jbarry
Jun 2017
Cork
Hi All,
I'm a total newb, so be gentle.
Does anyone know what is the equivalent amount of bits to Allen Bradley packets?
I was looking up a technical data sheet for a 1756 ENBT Etherrnet module to assess it's comms traffic capacity as I had an issue on a customer site. The data sheet stated the module had a Packet Rate Capacity of 5000 packets/second for I/O and 900 packets/second for HMI (see Table 3 at: http://literature.rockwellautomation.com/idc/groups/literature/documents/td/1756-td003_-en-e.pdf).
Comms isn't my strong suit (but I'm trying to learn). Any insight/info/learning is greatly appreciated.
JB
I don't think it's very useful to think about the theoretical output. It does you little good in practical application. To really get a better understanding of how ethernet works, i would look into the CISCO courses, a lot of free material on youtube, etc.
for Etherenet/IP, get the Rockwell's capacity tool:
https://theautomationblog.com/how-to-get-rockwells-ethernet-ip-capacity-tool/
I have a CPU simatic 300 with a single CP343-1 Lean as server Modbus on TCP/IP. Some function blocks (Siemens modbus TCP/IP Library) convert S7...
5,717
Hi all, I have a project which utilizes an L-33ER CompactLogix (v32), which will communicate with a RIO rack with a 1769-AENTR card in its Slot...
790
I have a system that is using TCP sockets. There are 5 connections between the Ethernet card and the end devices (smart conveying system)...
700
I have a grundfos Hydro pump skid with a cu 352 ethernet card communicating with an allen bradley 5069 compactlogix controller. I have the aoi in...
2,617
Hello, I have a mitsubishi A800 drive with A8NEIP_2P that I'm trying to communicate with AB Ethernet/IP Card 1756 ENBT/A. I have everything setup...
1,314
