Ethernet Comm RS Logix 5000 and Keyence vision
Mar 2011
Nashville, TN
27
I have a Keyence camera CV-3502P. Running a compact logix L35E. The camera has an ethernet port. I can communicate with it and sens and recieve data from camera using hyperterminal. I can't seem to get it to send and recieve through the plc. I have followed the examples from keyence, however it was for a higher up model that supports ethernet with plc.
Is there a way to send hyperterminal style commands out of the plc and recieve?
Jimmy:beerchug:
Jimmy:beerchug:
Unless the camera specifically says that it support ethernet/ip, I would venture to say you're restricted to using the PLC's com port in user mode and sending commends like you did with Hyperterminal.
We are controlling a flow rate in the process water system using a control logic L62 processor (RSLogix 5000 ver. 20) and an Endress Hauser...
2,634
Hi guys, i've got an odd one for you: I have a compactlogix L23E PLC. I did a bunch of programming at my shop, loaded ethernet modules for...
10,473
Dear Sir, I want to communicate Micrologix 1100 with Cimplicity 7.5 using AB ethernet without OPC server. Is it possible? Please help me...
3,184
Hi; In a cabinet of a machine, a Fatek PLC with an Ethernet communication card is working. In the same cabinet, there is a 1 kW inverter. When...
537
Hi all, I have a project which utilizes an L-33ER CompactLogix (v32), which will communicate with a RIO rack with a 1769-AENTR card in its Slot...
798
