Ethernet Communication - Determine if it will work
Timeismoney08
Jul 2012
United States
312
Question,
We have a company outside of the US providing us with an Automation device. The concern I have is that it will not be able to talk over Ethernet/ip or Modbus/tcp.
In general terms, what is the best way to get data from their PC to our PLC? They have software engineers who can assist, but with my lack of knowledge on the PC side, I can't say for sure that it will talk to our system.
Should I tell them they have to use Kepserver? Or only request that they can talk Modbus or Ethernet/ip?
Thanks in advance!
What software are you planning to use to get the data from the PLC?
Ask the supplier what Ethernet communications protocols their device supports and then check to see if your data acquisition software supports any of the ones supported by the equipment. If you can't find a protocol common to both devices you will need a third party interface from someone like Red Lion or Anybus.
if the transmission will be through the WAN the protocol to choose should be OPC UA, it offers encryption and security via trusted certificates. If the PLC doesn't have an integrated OPC UA server then a server should be installed on some PC near the PLC.
I normally write my URS to be explicit
100 - System shall communicate to the blah blah Control system via Ethernet I/P. (Assuming your preferred method is Ethernet I/P, replace for Profinet or whatevs)
So i'd just update your spec to be specific. Let them propose a solution and then review it.
I'm retrofitting equipment, but I didn't want to change the electrical characteristics of the panel. In this equipment I have a dedicated...
68
I have a contractor at my water plant installing 3 brand new Powerflex 7000 VFD's for my High Service pumps. I would like to control these via...
1,004
Hi All, We are planning Establish communication between Power Energy Meter (Schneider PM5320) with Rockwell PLC. I am unable to get the Assembly...
758
Hi All ... In one full plant, all machines are connected to networks. above 500 ip address... that consists of plc,servo,hmi and third party...
1,549
Hi All, I have a requirement of communicating my 5380 CPU with Zebra ZT411 Printer. Is there any one who did this before ? Do we need to have...
922
