ethernet communication on controllogix5000
Hanjaya
Jun 2009
Jambi
dear all,
i have redundant controllogix5000 that using Ethernet module to communicate to HMI through the Ethernet hub.
my problem are, now both Ethernet link from primary and secondary to our hmi is suddenly down ( the link led is solid green not red). i told to my boss that we only need to unplug the Ethernet cable and connect it again to get it to com again, but one of my friend say that we can't do that cause it will make the controller fault.
is that true?
please help.
SMC : "Archestra System Management Console" where I believe after restart of workstation you may need to activate DA Server. I hope I am pointing you to correct direction.
it fix now, when we unplug the ethernet cable from the primary module, the redundancy work and control is take over by the secondary module and the communication to the hmi is working...
thanks all...
I need to learn a lot...
I'm retrofitting equipment, but I didn't want to change the electrical characteristics of the panel. In this equipment I have a dedicated...
71
I have a contractor at my water plant installing 3 brand new Powerflex 7000 VFD's for my High Service pumps. I would like to control these via...
1,007
Hi All, We are planning Establish communication between Power Energy Meter (Schneider PM5320) with Rockwell PLC. I am unable to get the Assembly...
763
Hi All ... In one full plant, all machines are connected to networks. above 500 ip address... that consists of plc,servo,hmi and third party...
1,554
Hi All, I have a requirement of communicating my 5380 CPU with Zebra ZT411 Printer. Is there any one who did this before ? Do we need to have...
928
