Ethernet Switch
Engineer_UA
Oct 2016
California
43
Hello,
Is it true that a typical ethernet switch can manage several communications protocol as part of its functionality. For example, it can route data on DNP3 and Ethernet/IP networks all though a single switch.
Thanks,
EE
Yes.
An ethernet network with its cables and switches establishes the transport layer with which two devices can exchange bytes between them, the protocol they use to communicate is independent of cables and switches, or whether the network is wired or wireless
Switches operate at layer 2 of the OSI stack. At this level, the protocol(s) being used does not matter. These might be called switches or "layer-2 switches". Although, layer-2 is really a redundant term since every switch supports this layer. The term is typically used to separate standard switches from layer-3 switches.
Smarter layer-2 switches (aka managed switches) may have features to recognize certain types of data and perform action on that data. That might be prioritizing or maybe even discarding that data.
Some switches are called "multi-layer" or "layer-3" switches. These introduce some routing capabilities that previously required routers.
In summary, an Ethernet switch can really handle any Ethernet traffic, whatever protocol is being used. But it might have special features to allow it to do more with certain data types.
OG
Hi, I'm working with a Phoenix Contact FL NAT 2304-2GC-2SFP Ethernet switch, I already set the IP address and it has been working fine. I can...
1,442
Hi, I'm setting up comms at a station and I'm working with Cisco IE 3400H switches. I have been able to configure them following the Harware...
613
Other than Allen Bradley. Who else makes EtherNet/IP prioritized switches? I am looking for 5, 8, 12 Port 1000Base (1 gig) Unmanaged Wago and...
1,676
Anyone know of USA built or assembled un-managed industrial Ethernet switch. 4, 5 and or 8 port configurations? Thanks,
1,627
I am planning a new system and want to use a CompactLogix 5370 L2 with a PanelView Plus 7, and I plan to use ethernet communications between the...
1,126
