Eurotherm 590 DC Drive setup
EdwardBS
Guest
E
Hi...
We have used Eurotherm 545 series DC Drive and we replace using 590 series DC Drive. The application using for unwind application. The existing is using analog tacho as speed feedback, speed ref from S5 PLC. We have "feedback speed alarm" problem since we change to 590 series and run the machine.
How to solve this problem?
Thank you
Edward
More information would be helpful
What exactly is the fault you describe, is this on the drive or on the siemens ?
Which 590 is it exactly and what wiring did you swop over from the 545 to the 590 ie 545 pins - 590 terminals ?
Did you tune the drive ?
Did you set the drive up correctly ie ramps, current limit etc etc ?
edit:
After looking at my manual for a 590 digital (not an analogue or +) which i presume is what you have your error from the manual is as follows
This alarm means that the drive is not receiving a signal back from the tach in the form it expects to see. It may be scaled wrong, the polarity may be backward, or it could even be an AC tach and the drive is looking for a DC tach.
You need to read the instruction manual carefully to get these to match up. Usually, the tach has its own nameplate which gives you its output.
Has anyone out there ever set up a 590+DRV as a helper (load sharing) drive? I have an old (early 80's) Marathon drive that I'm trying to have the...
4,046
I have just finished testing some panels and have attached the devicenet and logix files Apart from rung comments etc is there anything i am...
3,776
First time I've used either the software or this unit. This is the setup I have right now. I have 20mA coming into AnalogIP1. Both the Main.PV...
57
Saludos amigos. Tengo una impresora comexi modelo FS1500, la impresora usa intouch 7 en Windows 2000, viene con un PLC Omron C200HS, también usa...
1,101
I'm just needed the iTools to configure the settings using RS485. Unless I read it wrong it is FREE for just that purpose. I went on Eurotherm...
613
