external monitor to view stats from panelview HMI
Can you elaborate? I would like to keep systems intact and add necessary component to send VGA/HDMI signal to monitor for visibility by management team.
A VGA or HDMI monitor is dumb, there must be something smart that computes info from PLCs in order to send it the to the monitor. Here is where weintek boxes can do their jobs.
Panelview terminals do not have VGA or HDMI output.
This is what drove me to ask for solutions...The headless unit I am getting to prove out and demonstrate looks to be more than capable, have tons of old monitors that are perfect displays to mount up for visibility...hoping that once I show them extended capabilities for MQTT, etc, that instead I can just put their cells into system so they can call up any number of machines instead of having to "Walk the floor". I agree that info is the king of operation data and having it on demand would make life easier. Thanks for the input.
Pat
Hi
just in case you are struggling on how to retrieve data from B&R PLCs, you may want to check out pltrend.at.
Connect via PVI to PLC and stream to MQTT broker.
This solution already saved some people the day :)
Regards
Manfred
Does anyone know how to drive an external monitor from a Red Lion HMI? It could be either a G3, or a Graphite. I have a customer that wants a...
2,355
I have a few questions about Studio5000. 1. Why is my RA folder so big? its well over 100 GB. 2. How do you delete versions or extra files...
279
I am trying to enable an external alarm via computer speakers for Factory Talk Network Distributed Edition. I am using Alarm and Events setup. I...
177
Good evening all! I hope you folks are doing alright today, as I've got a situation that I believe I've come up with a solution to but I wanted to...
447
As the title says, I'm trying to figure out a way to import and export recipe files from an external CF card to a USB drive and vice versa. I've...
497
