External window call in Factory Talk
pabluende
Oct 2008
Buenos Aires
Hi all.
I have a problem calling an external prog in Factory Talk.
I trying to do the following:
In order to use the RSView Enterprise File Viewer to view and export local data bases .dat into .csv, i set the command "AppStart" to open the explorer window directly in the log folder archive, and then select the file to open. The problem is that the window doesn´t appear as active window. I allready try with the "AppActivate" command but it did´t work.
I use Factory Talk SE 6.0 in Windows 7 pro.
Thanks in advance
I have a few questions about Studio5000. 1. Why is my RA folder so big? its well over 100 GB. 2. How do you delete versions or extra files...
278
I am trying to enable an external alarm via computer speakers for Factory Talk Network Distributed Edition. I am using Alarm and Events setup. I...
175
Good evening all! I hope you folks are doing alright today, as I've got a situation that I believe I've come up with a solution to but I wanted to...
446
As the title says, I'm trying to figure out a way to import and export recipe files from an external CF card to a USB drive and vice versa. I've...
497
Hi All, I'm using Studio 5000 ver 30 to modify existing logic that has PID, and I want to be able to use an external/remote source as a setpoint...
638
