Extracting data out of SLC500 PLC to excel
protrac231
Dec 2009
tampa
19
Does anyone know how to get a status bit out of a AB SLC500 plc and provide it to Excel??? Can i use ODBC? Does anyone on have an example of this?
I need to do this so i can get data from palletizers to a label printer.
Thanks for any help.;)
I am using Linx pro. I am more asking for the how to do it.
I realize you are asking for the HOW. Just thought i would clarify the use of PRO before we got too far along.
This in an example of an instruction I have used in Excel to import data from an PLC 5/20
The 9512637 is the name of the PLC file.
=rslinx|'9512637'!'n67:1'
Easy
· Open RXLinx
· Click on “DDE/OPC”
· Click on “topic configuration”
· Click on “New”, create a topic and click “done”
· From RSWho, select the PLC you need to get the data from
· Click on “Station” (top of screen) and then select “data monitor”
· From the table that will come up, select the data table where the data is (B3 Binary for example)
· From the data file table that comes up, right click on the bit you need to monitor and select “copy to clipboard”
· From the window that opens up, select the topic you created and click “OK”
· Open Excel
· In the cell you want the data to reside, right click and select “paste special”
· From the box that opens up, select “past link” and click “OK”
The data should now update about once a second. You can increase or decrease this speed in the “DDE/OPC Topic Configuration” box under the “Data Collection” tab.
Happy programming.
Hello, I currently have a factory talk project (Project 1) that uses visual basic to calculate an integer. I am in the process of developing a new...
1,332
Hey all, I've got an array in a Control Logix program that has initial values in each element of the array. I want to extract these values from...
1,966
I am attempting to access HMI tag properties (Description, Minimum, Maximum values) to populate a numeric input. Is there a clean way to do this...
383
Hi all, I have a customer with an FTView SE system running some datalog files. They can see the trends on the client, but they now want to...
2,739
Hi, I'm using the 2080-MOT-HSC High Speed Counter plug-in module with a Micro850 (2080-LC50-24QWB) using the HSCE instruction. The encoder is a...
1,675
