factory talk view 6.10 ME tag browser problem
italo2008
Feb 2009
Padova
95
Hi everybody
I've created a very simple project with rslogix 5k and ft view ME 6.10
this is is my hardware:
Panel view plus 1000
compact logix L32E
everything communicate using ethernet
I set up communication in rslinx enterprise, downloaded and tested and everything works fine, but if I need to add a tag in the PLC program and visualize it in the panel, when I create (for example) a numeric display and try to connect it to the new tag, the tag browser doesn't show me the last added tag, but just the old tags. I tried to refreh folders, save, close and reopen everything but nothing to do... Only shutting down my pc and reboot I see the new tag in the tag browser....
does someone can help me?
135
Hi all, Attached below is an example of what is happening to our existing SCADA. It seems after patching some Rockwell Software that I thought...
335
The client has an application that when communication between the PLC and the Factory Talk VIEW supervisory fails, the object in the supervisory...
296
Hello all, I am looking for a way to have a user get logged out after an X amount of time because to default so that user privilages are no...
601
Hello everybody. I was wondering if there is a way in FTVIEW Studio to close ) view after x min without interaction . My issue is the following...
375
