Factory talk view alarms
Rehu09
Nov 2017
USA
64
Hi all,
1. I'm working on alarms in FT view ME with rslogix 500. I have seen all the alarms in my plc program are kept in the N7:1 and N7:3 out of which all bits for N7:1 is used and 9 bits for N7:3 is used.
So right now I'm creating the alarms messages for N7:1
I went and created tag with name ALARM1 digital bit and used the device address as ::[shortcut]N7:1/1 and then used the same alarm tag while creating alarms and kept trigger value as 1.
But while reading some post, few of them has mentioned to use L16 L32 in address bit ::[shortcut]N7:1(L16)
Can't I use this ::[shortcut]N7:1/1 ?
2. Basically I'm converting pv550 to pv700. So I went and check alarms in pv550 in panelview 32 and I have seen there we have use "ack tag" as N7:2. because in plc program it was mentioned in description of N7:2 as ALARM RESET ADDRESS ARRAY.
DO I have to use this N7:2 in acknowledging the alarms.
Please some one help me
From top of my head L16 means you are using array of 16 elements (tagname[0..15]) and L32 would mean you are using an array of 32 elements (tagname[0..31]).
You can try using {::[shortcut]N7:1,L3} assuming your N7 register is an array of 3 elements. This will be your trigger. Then each of your alarm need to have trigger value - bit numer
See example from one of my projects
iqjpWn
123
Hi all, Attached below is an example of what is happening to our existing SCADA. It seems after patching some Rockwell Software that I thought...
329
The client has an application that when communication between the PLC and the Factory Talk VIEW supervisory fails, the object in the supervisory...
293
Hello all, I am looking for a way to have a user get logged out after an X amount of time because to default so that user privilages are no...
595
Hello everybody. I was wondering if there is a way in FTVIEW Studio to close ) view after x min without interaction . My issue is the following...
374
