Factory Talk View Data Logging
Mihir_007
Apr 2014
Reading
66
Dear All,
Having a trouble in data logging in FTV-7.0 SE. As ODBC data base is generated and using VB coding, an application is created which will give an output in Excel sheet by taking reference from ODBC based .mdb file.
Earlier it was running OK, but then after i have added some tags in data log model which is creating an error while fetching data in excel sheet.
Screenshot of that is error is as follow.
Hope you guys can help me.
-Mihir
system.ArgumentException: Count OF coloumns must be equal to table.Column.Count
Parameter name: columns
at DataFromAccessDB.Form1.ReorderTable(DataTable& table, String[] columns)
at DataFromAccessDB.Form1.button1_Click(Object sender, EventArgs e)
132
Hi all, Attached below is an example of what is happening to our existing SCADA. It seems after patching some Rockwell Software that I thought...
333
The client has an application that when communication between the PLC and the Factory Talk VIEW supervisory fails, the object in the supervisory...
293
Hello all, I am looking for a way to have a user get logged out after an X amount of time because to default so that user privilages are no...
597
Hello everybody. I was wondering if there is a way in FTVIEW Studio to close ) view after x min without interaction . My issue is the following...
374
