factory talk view machine edition - languages
italo2008
Feb 2009
Padova
95
Hi
I'm learning to use factory talk view machine edition. I must develop a project with 3 languages. If I need to put (for example) a textbox in a page of the project, and write it in 3 languages, how can I do it? is it necessary to close and re-open the project with one of the other languages? Is there no simpler way?
thank you
Ciao, actually there isn't a way to switch from one language view to another inside the development...:confused:
Basically, you've to create your application using the "base" language you prefer, use the language settings to add the desidered languages and, after that, you may export all to a .csv file, open it using Excel, add the needed translations and re-import.
There should be buttons on your runtime project to switch from one language to another, too.
I suggest to review the User Guide, chapter 12.
- fuzzy logic
159
Hi all, Attached below is an example of what is happening to our existing SCADA. It seems after patching some Rockwell Software that I thought...
353
The client has an application that when communication between the PLC and the Factory Talk VIEW supervisory fails, the object in the supervisory...
306
Hello all, I am looking for a way to have a user get logged out after an X amount of time because to default so that user privilages are no...
629
Hello everybody. I was wondering if there is a way in FTVIEW Studio to close ) view after x min without interaction . My issue is the following...
385
