Factory talk view ME on industrial PC
Breadman
Aug 2019
Home
Hi everyone
I have a dough mixing system on our plant that uses slc504 as a plc and wonderware intouch as a HMI.
The application is reasonably small (about 8 screens) and straight forward.
Coms is DH+ through a DH+ to ethernet converter.
Industrial PC is a Rockwell 6181P-15A2MW71AC
i have had a system integrator quote to replace this system using compactlogix and factory talk view me.
My question is whats involved in running factory talk view me on an industrial pc. I know it runs on the panelview plus 6 & 7 hmi's but never heard of it on a windows 7 industrial pc.
If it can be done.
Would standard factory talk view studio software licence that i use for the panelviews be able to make changes to the application?
Thanks in advance.
You need to buy and install ME Station. This is the runtime that will run a MER on windows. ME Station is what allows you to test run your applications within factory talk view studio ME, it is just unlicensed, so it only runs for 2 hours
You need a licenses for ME Station. Issues i had was it liked to be ran as an administrator. ME Station doesn't seem to like it a lot if your IT department has strict security restrictions.
140
Hi all, Attached below is an example of what is happening to our existing SCADA. It seems after patching some Rockwell Software that I thought...
335
The client has an application that when communication between the PLC and the Factory Talk VIEW supervisory fails, the object in the supervisory...
298
Hello all, I am looking for a way to have a user get logged out after an X amount of time because to default so that user privilages are no...
606
Hello everybody. I was wondering if there is a way in FTVIEW Studio to close ) view after x min without interaction . My issue is the following...
375
