Factory Talk View ME screen issues
Daandine
Jul 2016
QLD
Good afternoon,
I am running Factory Talk View ME on a Getac 'toughbook' touchscreen laptop.
I am having issues having my Factory Talk program screen fit fully on my Getac laptop screen, however it will fit perfectly if I use an external monitor.
Is there a trick in Factory Talk ME or or Studio 5000 that allows me to reduce the size of the program screen output so that it will fit on my Getac?
I have already tried changing Windows 7 resolution settings, tiling and have tried some other screen sizing softwares.
Any help would be greatly appreciated.
sounds to be your Laptops graphic card available settings
the resolution for an external monitor is via the VGA port
your issue sounds like you cant set the correct setting
as a test reduce your font size
who's brand is GETAC
148
Hi all, Attached below is an example of what is happening to our existing SCADA. It seems after patching some Rockwell Software that I thought...
340
The client has an application that when communication between the PLC and the Factory Talk VIEW supervisory fails, the object in the supervisory...
301
Hello all, I am looking for a way to have a user get logged out after an X amount of time because to default so that user privilages are no...
615
Hello everybody. I was wondering if there is a way in FTVIEW Studio to close ) view after x min without interaction . My issue is the following...
380
