Factory Talk View Migration - Strings
simona78
Jul 2011
Timperley
Good Morning. I'm migrating an old PB32 application onto Factory Talk View Studio (A PV+ 1000) so we get improved alarm logging. The PLC is an SLC500 and the problem I am having is that within the PLC there is quite a lot of text data stored in 'N' files. I've set up my string tag to read 6 characters from, say, N50:21, but on the screen I get '??????' displayed. I've tried not using a tag and just accessing N50:21 directly to my object, but then I get the first two bytes (because I've not specified a read length) represented as a number instead of the implied ascii, ie 12345 instead of '09'. PB32 coped with this no problem, and as I can't find any reference to this I suspect Factory Talk does but I'm being daft. The PLC is running an assembly line in a car plant so I can't add 'A' type data files in as reloading the PLC isn't really an option. Advice please!
Welcome!
Text would normally be stored in a String file ST while Integers would be stored in N type data files.
If possible post both PB32 and RSLogix500 programs zipped first.
Hope this helps.
Bob, The line/machine has 'evolved' over a long period of time to be where it's at today - I'm not really in a position to start moving the text around so it's all in 'ST' or 'A' type files. PB32 evaluated a byte as a byte and would display in whatever format you told it to, however the new fangled FT View ME seems to interpret the 'N' file only as a number. Is there a way to 'force' the HMI software to interpret the 'number' as ASCII?
117
Hi all, Attached below is an example of what is happening to our existing SCADA. It seems after patching some Rockwell Software that I thought...
329
The client has an application that when communication between the PLC and the Factory Talk VIEW supervisory fails, the object in the supervisory...
292
Hello all, I am looking for a way to have a user get logged out after an X amount of time because to default so that user privilages are no...
595
Hello everybody. I was wondering if there is a way in FTVIEW Studio to close ) view after x min without interaction . My issue is the following...
371
