Factory Talk View SE - Security Accounts problem
saeqsae
Jul 2019
Concepcion
45
Hi all, i have some issues with the security accountes.
I create an administrator account who doesn't have access to the "Manual control display" on my application. I put the security of the display on "A" and my administrator account only have permissions from "D" to "P".
But in the client, when i logging with the account i can access to the display with "A" security.
Did i do something wrong or miss a step? Thanks in advance
Most likely the user account is part of another group that has permission to view that screen. Permissions are cumulative. For example:
User: MyUser
Member of: ENGINEERING and ALL USERS groups
ALL USERS has security: ABCD
ENGINEERING has security: EFGH
As a result, MyUser has effective permissions of: ABCDEFGH
Check the effective permissions.
1. Open Runtime Security, Click Security Accounts button.
2. Click the Effective Permissions tab and then click on the "..." ellipses button.
3. Select the user to check and click OK.
4. Expand FT Security Codes
You can now see if that user has specific codes.
OG
Thanks, that was the issue, my administrator account has permissions from A to P, now i have another issue, when i wanna access to my application on the client send me a message saying "You do not have security privileges to access this application". How do i solve this?
Is this a new error message or a message you were seeing before? In solving the previous issue, hopefully you did not remove the ALL USERS group.
Open FT View Studio and access the Runtime Security. Make sure the ALL USERS group has not been removed and has at least one security code assigned to it. It can be any code, it just must have a code assigned.
OG
117
Hi all, Attached below is an example of what is happening to our existing SCADA. It seems after patching some Rockwell Software that I thought...
329
The client has an application that when communication between the PLC and the Factory Talk VIEW supervisory fails, the object in the supervisory...
292
Hello all, I am looking for a way to have a user get logged out after an X amount of time because to default so that user privilages are no...
595
Hello everybody. I was wondering if there is a way in FTVIEW Studio to close ) view after x min without interaction . My issue is the following...
371
