Factory Talk View SE - Trend Pro
smess.cle
Feb 2020
Marseille
HI everyone,
I wonder if there is a way to show some Backward or forward arrow buttons in Trend Pro (the same way we have in the trend graph).
They are so handy.
See attached image.
I think since you can just click within the trend and scroll left or right, the buttons just became unnecessary. I've never bothered trying to add buttons, but perhaps someone else has
OG
OG
Hello OG,
Thanks for your answer,
Do you mean click, keep clicking and move the mouse left and right?
If yes, the issue with that is it does scroll left or right, but is is as well "Moving" the graph on the Y axis. when usung the stack Y-axis viewing mode, the graph become partially hiden if by mistake you would have move your mouse on Y axis as well AND it does not scroll by regular period of time (backward 2h ie)
Any idea?
...the issue with that is it does scroll left or right, but is is as well "Moving" the graph on the Y axis. when usung the stack Y-axis viewing mode, the graph become partially hiden if by mistake you would have move your mouse on Y axis as well AND it does not scroll by regular period of time (backward 2h ie)...
If you hold the SHIFT key while moving your mouse it will only affect the X-axis. But that doesn't resolve scrolling back in regular periods.
There is not a VBA Method listed for scrolling the X-axis so it doesn't look like we can do VBA code. You can have pre-defined time periods triggered through VBA, but I don't see a way to scroll back in increments like the older Trend object.
OG
147
Hi all, Attached below is an example of what is happening to our existing SCADA. It seems after patching some Rockwell Software that I thought...
339
The client has an application that when communication between the PLC and the Factory Talk VIEW supervisory fails, the object in the supervisory...
300
Hello all, I am looking for a way to have a user get logged out after an X amount of time because to default so that user privilages are no...
613
Hello everybody. I was wondering if there is a way in FTVIEW Studio to close ) view after x min without interaction . My issue is the following...
379
