Factory talk view studio and data logging
Robb B
Feb 2011
BC, Canuckistan
362
I'm trying to setup a trend to save data for two sources (both in a compactlogix) so that tends can be viewed over the past few months. I can create the trend, and get the data to display if I select real-time data source. When I select the data log model and choose the data source on the general tab of the trend I configured, I get no trending (or error).
I went to the data log directory, there's only 3 days of data from April, then it stopped. Logs somewhere that would explain what happened? How do I get that data logging to start when the application starts?
Well I read the manual a bit further, and found the section where to enable data logging at startup as well as run macros, but still no idea why it stopped.
124
Hi all, Attached below is an example of what is happening to our existing SCADA. It seems after patching some Rockwell Software that I thought...
329
The client has an application that when communication between the PLC and the Factory Talk VIEW supervisory fails, the object in the supervisory...
293
Hello all, I am looking for a way to have a user get logged out after an X amount of time because to default so that user privilages are no...
595
Hello everybody. I was wondering if there is a way in FTVIEW Studio to close ) view after x min without interaction . My issue is the following...
374
