Factory Talk View Studio HMI tags
djpalaz
Jan 2007
Montreal
57
Hello,
I created a tag under HMI tags. When I open two SE clients both clients can modify the same tag. Is it possible not to share the tag so that each client can put have its own value for the tag. The tag value will not be the same for each client. The tag value will be used at a later time by the client.
HMI tags are the same for each client.
If you want to have a tag for each client, you should create different tags.
Try to create a dynamic call of the tag, with the name of the pc for example.
Or another solution is to not use a tag but a Visual Basic variable.
What would you like to do ?
Hello Snyve,
How do i create a dynamic call of a tag?
I am using vba to write to the tag. But it seems that the vba variable is still common between clients. I would like each client to have in memory the previous screen they were at. I created the following code to retreive the name of the screen:
Private Sub HomeButton_Released()
Me.PreviousPageTag.Value = Me.Name
Me.PreviousPageTag.Download
End Sub
The PreviousPageTag is the name of the StringInput. The StringIput then writes to the PreviosPage HMI tag.
Hmi tags are the same for each client, but not the vba variable.
If you want to create a button to return to the previous window, try this:
Create a rsview button and in the button properties (not in vba) tape this: Prevwindow
and a button to return to the previous window is created.
if you want to create a dynamic expression:
In your vba code, you can use this:
Dim strClientName As String
strClientName = Environ("COMPUTERNAME")
with this code you have the name of the computer and then create a different variable for each computer
ex:
if strClientName = "PC1" then
use your code and replace Me
else
if strClientName = "PC2" then
150
Hi all, Attached below is an example of what is happening to our existing SCADA. It seems after patching some Rockwell Software that I thought...
346
The client has an application that when communication between the PLC and the Factory Talk VIEW supervisory fails, the object in the supervisory...
303
Hello all, I am looking for a way to have a user get logged out after an X amount of time because to default so that user privilages are no...
619
Hello everybody. I was wondering if there is a way in FTVIEW Studio to close ) view after x min without interaction . My issue is the following...
381
