FactoryTalk Gateway handle more than one application
Apr 2011
Manila, Philippines
295
Can FactoryTalk Gateway be able to handle more than one SE View considering that the projects are in different application?
In our case, two factorytalk view projects must be expose to a third party application as one OPC server.
Thanks!
Hello Everyone, I'm using Factorytalk Linx Gateway V6.30 with Nov 2022 patch in order to publish tags from a network distributed FT system to...
928
Hello. I need to support a customer who is developing a custom OPCUA client that needs to read data from CompactLogix using the FactoryTalk Lynx...
1,482
Hello all, I have what has become a complex problem, with what I'm hoping is a simple answer. I am using FactoryTalk Linx Gateway set up as an...
2,393
Hello all, In a current project we are trying to connect an R.A PLC (CompactLogix) to an OPC UA client/server. To do so we first installed...
6,424
I tried doing this by adding a remote opc server running wonder ware on an Opto22 controler using ethernet. The topic comes through and is active...
2,133
