Bob.Boerst
Hello,
Thanks to any help on this issue.
Project Info:
FactoryTalk ME v11 Panelveiw Plus 7
Compact Logix 5069-L320ER v30
Comms = Ethernet
Operator enters setpoint values using “Numeric Input Enable Properties”
Properties Tabs:
Label = /*N:5 {[Addback]Addback_HMI_SP[8].HMI_Proc_Entry} NOFILL DP:2*/ sec
Numeric popup = Keypad
Timing
Delay = 400 ms hold = 250 ms handshake = 4 sec reset = Non-zero value
Connections
(See attached pdf)
When testing runtime and opening the display I get “The item no longer available”.
Although all entries are present and correct - some but not all tags appear to be inactive.
When opening the numeric popup entry the window is asterisks
Thank you for any direction on this problem.
Project Info:
Comms = Ethernet
Properties Tabs:
Timing
Connections
(See attached pdf)
