FactoryTalk SE Distributed Crashing during Login/Logout
NikkoSuave
Dec 2016
Middle of No Where
17
Title describes the problem. We implemented an FT idle detection control to auto logout the user to view only and started to notice the FT client will crash when logging back in.
After some debug, I do not believe it has to do directly with the idle detection control. If I stand at any of the HMI and log in/log out repeatedly, it will eventually crash and come up with the windows dialog box asking to debug or shut down the program.
I cant trace where this is coming from. I called support but it didn't seem they knew where the problem was coming from either. Has anyone seen this problem before. I've attached an image of the windows dialogue details area.
release number is 8.10.00
Patch/Pack number is 00
Build Number is 13
I hope this is the information you are looking for. I got it in the about section in my development studio.
Installed patches wont be indicated there. You need to look in the Programs and features. I had a similar issue that was corrected by a newer FTSP release. what release is your FTSP?
I couldn't find any patches installed on any of the servers we are using for this project. I am unfamiliar with everything that was installed on the servers we use, as this is a large project and that task was given to another supplier.
Our factory talk services platform is 2.74. Can I ask what had you updated yours to?
Alarm Server Connection Status I am trying to tie a color animation to a rectangle that changes color when connected or disconnected from the...
531
Hello, I am trying to make a copy of a FactoryTalk SE Network Distributed application. I want to make modification but do not want to work on...
1,169
We are cutting over a PLC5 to ControlLogix and we ran into some issues with the HMI (FTView v10, Network Distributed). We found that after...
963
What is the main difference between the 2 licenses? I have a lot of experience with the Machine edition but not so much with the Server Edition...
4,183
Hi Folks, I am having a bit of trouble with a Factorytalk View Studio Network distributed application (Surprise surprise) after restoring a...
1,097
