FactoryTalk View Hotkey
frorge
Jun 2011
Texas
Does anyone know if you can program hot keys or shortcuts for common button or features in factorytalk view? I've searched but to no avail. TIA
ME
I see what you are referring to, but I can only see how to assign F Keys for use in runtime. But i'm talking about hotkeys to create programs. Much like you have in AutoCAD, shortcuts to allign, arrange, create push button, etc....
No. The Studio software does not have means to customize the key functionality beyond the built-in hotkeys.
Yes, the "runtime" Station environment can assign uses to the "F" and "K" keys in the Machine Edition. SE allows for even more, but still only in Station, not Studio.
I remember running across a freeware or shareware software utility that allowed you to create keyboard macros for different programs. But its been ages since I saw that. There may still be something out there.
OG
ME
If you click on the different items on the menu bar you will notice that in the drop down menus all the available keyboard shortcuts corresponding to the different options are given.
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
198
Hello, I'm using FactoryTalk View ME V10. I created a valve as a global object with multiple parameters and when the object is being used at the...
134
Hello all, I was modifying an HMI in factory talk and went to change a go to display button using the ... to select from a list as I had done...
181
Hello, We recently upgraded our control server to a newer model. After the transition we are experiencing issues with our trend graphs to where...
124
Hi, I wanted to ask is there a way to have a visibility expression use the IP address of the HMI (Dynics, not PV) to show certain elements? The...
208
