FactoryTalk View ME - User logging
EICS
Dec 2008
Melbourne, Australia
323
in FactoryTalk View ME V9.0 i have been requested to log when a logged in user does a certain function (modify a recipe in PLC)
i have 4 users configured, i need to know which user is modifing the recipe and need to write this info "string" into a plc (1756-L73) String variable to send to a scada report. i can handle the string to scada from the PLC
i am unsure what i need to do to write the logged in user of the HMI to plc ?
thoughts please.
Some people run a script that changes a number when ever a person logs in, that number is tracked on the PLC side.
UserDINT !== CurrentUserDint -> UserDINT MOV CurrentUserDint
I don't have an HMI next to me that I could spin up, to test.
The thing I was more curious about, if you have 4 users and I assume they're shared accounts. How are you tracking the WHO?
thanks for the reply Van i have a HMI on my bench, i will give it a shot tomorrow !
i have 4 separate user accounts configured so i should not have an issue on that side.
all sorted.
my issue was you cannot create a macro directly to plc tag via online browse. i needed to create a local (hmi tag database) string tag then use that in the macro.
Hello is their a way to create a password that contains the following variables: 1) number of the day in the month, example 07 the 7th day in...
726
I have a FTView application that allows user management via the HMI. When I need to make a revision to this application, I upload and restore the...
808
Hello all, I am new here and this is my first post so I apologize if I am doing anything wrong. I am working on converting a Wonderware app to a...
8,021
We are about to turn over control of one of our facilities to a group that has no business operating it. When they inevitably cause problems and...
9,942
Is there a standard method for using RFID tags to handle user authentication with FactoryTalk ME? I've currently got several panels using the...
4,639
