FactoryTalk View SE Multi-state Indicator issue
Chibu
Feb 2023
Ontario
49
Hi Guys,
I configured some FactoryTalk SE multistate indicators but they only reflect state changes only after screen closure and reopening; also, when I talk them on the Screen they change state/colour.
Any ideas will be appreciated please.
Sometimes screen refresh rate is set too slow, causing no updates unless opening screen. Reduce refresh <1s and try
Hi Guys,
Touch***
Are these supposed to be multistate Indicators or multistate pushbuttons?
Multistate pushbuttons can have value change based on previous value or previous state. If the indicator tag does not change than the state value won't update properly. Change to a momentary pushbutton instead of multistate pushbutton and do logic in the plc instead of the screen if needed more than one pushed state.
They are Multi-state indicators, I'm wondering why they can't update in real time without reopening the screen; and colour change when touched.
Thank you jholm90,
I mistakenly used Multistate Pushbutton instead of Multistate Indicator.
I appreciate your input.
Hello, I had a question about benchmarking the Rockwell FactoryTalk View SE software. I've installed in the neighborhood of 30 different...
280
I am working on a new View ME project for a demonstration display using a PC Hosted version of ME Station. I would like to show a cylinder...
3,156
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
116
Hello, I'm using FactoryTalk View ME V10. I created a valve as a global object with multiple parameters and when the object is being used at the...
130
Hello all, I was modifying an HMI in factory talk and went to change a go to display button using the ... to select from a list as I had done...
177
