Fanuc Safety Module - Ethernet Network
joevue
Mar 2012
Michigan
:confused: Working on a single Fanuc robot cell. Could not get communication with the safety module in the robot controller. When I bring up the property box in the I/O configuration tree and view the "Connection" tap, I get the following fault:
(Code 16#080d) Safety network number not set, device out-of-box
Has anyone had this issue before and how do you resolve the issue. Any help
will be greatly appreciated.
Joe
First, what devices are you working with? Without part numbers, its impossible to really answer.
Even so, I suspect you can't do what you want without a Safety Controller that "owns" the safety module somewhere in the picture, too. It's not likely the robot controller can do this itself.
I'm working with 1756-L72S plc. Can't take ownership because there is no signature from Fanuc robot. This is thru Ethernet, I assume it would be similar to devicenet.
Hello Guys I have an 1756-L73S Controller with a Fanuc Robot mapped as follows: - In 1756-EN2TR Slot 2 the Fanuc Robot is defined as an...
292
Just wondering if anyone has had any experience with using a Fanuc Robot (R30iB) to a Logix 5000 over Ethernet/IP using Safety. I have some...
1,617
Hi Everyone, I am new to Fanuc robot, I have a question about the CIP Safety singal setup, please hlep! The plc is ab l36erms, robot...
2,356
I'm doing a safety evaluation for a robotic system using a FANUC robot with DCS. To do the evaluation I am using the Siemens online safety...
2,087
Good afternoon all, I have an application where a robot picks up a part off a transfer stand inside a robot cage and loads a milling machine. We...
6,755
