Fatek plc samplecode
Ayuda con control de temperatura
DEAR.
We are distributors of Fatek in Peru, I attach a program example, in you can see the managing of timers, counters, inputs analogs and outputs PWM, besides the control of temperature, I wait use you as help.
Best regards.
Angel Sandoval F.
www.tekperu.com
A&S Automatización Industrial S.A.C.
Buenos Dias, Sr. Angel Sandoval
Estoy programando un PLC Fatek, con un control de temperatura, pero a la hora de hacer la prueba las entradas de temperatura se activan en 28767 y no se por que, esto le a ocurrido?
Saludos
Alexander Rios
Buenas tardes, Sr. Angel
Estoy programando un control de temperatura con un PLC Fatek y los valores que me lee siempre son 28767, en la entrada analogica de temperatura, en mi caso 8 termocuplas, esto le ha pasado?
Por otro lado, como hago para programan deteccion de rotura o apertura de la temocupla?
Agradeciendo la ayuda que pueda prestarme
Saludos,
Alexander Rios
Hmm Maybe switch to another PLC
One that is more worldly supported
I been in this game for 40 years first time i heard of that
Hello,
Can anybody extend help on how to unlock or disable the FATEK FBs-60MA PLC password?
Your help is very much needed.
Regards
Just go to Project ----- Project Setup ------ Password, then apply existing password and then what else you want, new password or no password.
Hi everyone, i hope you are doing well i am using fbs 2lc module , i have calibrated the weight by calibrated weight but my value is not...
87
Hi; I have Laptop Lenovo Thinkpad (W10) which don't have built-in Bluetooth. I have a PLC having Bluetooth communication device. I wanted to...
137
Hi everyone I am using Winproladder software for programming FATEK FBs PLCs and in programming, we often use Timers for activation of the...
594
Hi friends, I have a problem. I want to read ASCII data over rs232 standard port. How can I do the reading process? FATEK FBs-CB25 -> port1...
751
Dear all, I want to use the interrupt service routine in FATEK PLC using WinproLadder Software. I had configured the interrupt in software as...
17
1,588
