sunnyvaleplc
Hi Guys,
I have a peculiar problem. I have a Compact Logix PLC, which is hooked to another device. I have a PERIODIC routine, which cycles at every 213ms and reads a bit from this device. If this bit is HIGH, its a fault and it should show up on the ALARM panel.
I have other Digital I/O which do show up as faults when they are HIGH, in the ALARM window, but they are part of the MAIN Program [Continuous task].
How do I set the ALARM list in the PanelView touchpanel to display this fault, which happens in the periodic routine.
Thanks,
Sunnyvaleplc
Thanks,
Sunnyvaleplc
