Showing PLC5 card comm/fault status in RSView32
OK. I think then I'll have to stick with just showing local and remote rack faults, possibly comm errors if possible. Is there any documentation out there showing step by step instructions for how to do that? Defining the diagnostic file, creating block transfers, etc?
Again, truly appreciate all the help.
If you post a list of the I/O, I am sure we can guide you bit for bit using manuals. The BTR/BTW modules all have status words that can be highly useful, but without a list of cards, I can't go look them up...
Use the rockwell automation literature library search for the catalog number of the cards, and sort the results by "Publication Type", "Descending". This puts user manuals and references at the top of the list.
Or post a list, and I am sure running examples can be gotten to go along with the manuals.
Paul
Good morning, We've had an issue with a couple of servo valves and was wondering if anyone had seen anything similar. After a drop in pressure...
106
Hello, I am using a Hitachi Micro EHV+ for a small project, and I wanted to have a Web visu, done with Codesys V3.5 SP13 Patch 2. I test the...
296
Hello. I am working in FTVSE v8. I have many trends set up some of them work others do not. The ones that don't work show the foot print of the...
241
Hello everyone, I am working in a platform and we installed FTV CLIENT SE V 12 IN ALL THE CLIENTS COMPUTERS, we have 6 clients and only 1 is not...
105
Searching edit zones within all routines and other criteria still says no results found, yet I still have the "edits present" indicator at the...
258
