flashing light to become continuous
Buy the non-flashing version. Siemens makes it both ways. If you want one that does both, it is simple enough to use the non-flash version and create a flashing output from your PLC.
You might trying "flashing" the output driving this lamp at a speed that is less than 1/2 its duty cycle. That assumes the lamp normally turns on when it first gets an excitation voltage and then begins its flash cycle after the initial time its been on. Your OFF time would be as short as you can get it to reset the lights flashing circuit.
To bypass the flashing function you would have to open the sealed electronics in the housing and rewire the power to the bulb direct.
This isn't feasible as trying to open the sealed portion would destroy the housing and bulb socket.
Maybe have a Bridgeport operator end-mill everything up to the terminals out of the housing and put your own bulb socket wired to the terminals
Hard to figure out this Siemens stuff. Datasheet says Single-Flash and flash rate of 1 Hz.
Also says life of LED is 50K hours, and lamp is Zenon.
If lamp is Zenon, continuous isn't possible.
That is a strobe light and cannot be made to stay on steady. Strobe lights are very different than other types of lights (LED, incandescent, etc…) including what it takes to power them.
Hi Guys, I have a 1769-L24-QBFCB1 that has the OK light flashing on the embedded counter module. The manual states it is a resettable fault, but...
104
I have a Micro820, yes I know they are hated. I have a brand new Micro820 that I programmed with a Micro SD Card. Once I got it programmed, I...
886
Is there any way to recover a L33ER flashing red OK light or is it just a paper weight?
2,162
Hello, I have built a panel with the following components in it. 5310 AB Panelview 5069-L306ER PLC 1606XLE120E power supply A circuit breaker...
1,951
Hey guys, I'm super new to troubleshooting PLCs and was hoping I could get some guidance I've got a machine I'm commissioning and it's kind of a...
27
10,549
