**** Flexy Connection Issue
Hal9000
Jun 2010
London
140
Hi there,
I'm in need of support in regard to an **** flexy that is consistently losing its remote connection at defined repeatable instances.
Issue
• The connection to the gateway is remote via GSM. It has worked many times before, but today I have an issue that is repeating itself consistently:
I can ping my gateway (192.168.0.100 and my PLC 192.168.0.1 which is plugged to the LAN port), however it will ping ok for 20s then timeout for 10s - this then repeats itself consistently. i.e. pings ok for 20, timeout for 10s repeat, repeat..
• Signal strength seems ok (4 bars)
• If I try to connect to the web server of the **** flexy I am disconnected at regular intervals, which ties in with the loss of ping messages.
Steps to try and resolve
I have reset the flexy back to factory default following the **** flexy 205 installation manual section 7. Following this I went through the three standard wizard set-up functions. All wizards worked ok and the unit is visible again on the ****** account, however I still get the connection issue.
I have tried an alternative SIM card (one I know works ok in my Cosy unit), but this didn't make any difference.
Any help appreciated..
Hi there,
Issue
Some (not all) network switches/ports exhibit strange behaviour when they have duplicate IP addresses detected.
- Cisco 2955s connect one address for 60 sec, then the other address for 60 sec, then repeat
- Anybus ethernet/IP interfaces on type 1 interface drop out .. but not repeatably ... that I could figure out
It's likely work a check to turn off your **** Flexy and then ping it to ensure there is no other device at that address
Hello, I presently have a Allen Bradley PanelView 5310 at a client site and i can access to the PLC/HMI local network with a remote module...
104
Does anyone have any experience of using an ***** Flexy for remote programming/maintenance of a Codesys based controller? Rather than using the...
234
I have an E.W.O.N Flexy 205 setup on a LAN with 4 PLCs and 8 HMI's and it's setup and configured with cellular modem and external antenna and I...
703
I have a 4g Flexy 205 using a verizon sim, which is supposed to talk to a 1769-L33ERMS safety controller. When the PLC is connected to any LAN...
1,724
I have a Flexy ew on set up with a 3g cellular card. Its LAN is connected to a PLC, HMI, and a VFD. I built a Vi ew on application and loaded it...
1,681
