FM350-1 Hardware config.
coopdegrace
Mar 2009
perth
34
Hi all, as I am new to this I am still having problems with my FM350-1 counter...When I try to download the new hardware configuration for the counter to the PLC I recieve this error "No DP master is assigned to the DP slave"? I am guessing that the program is looking for the address of a slave that is connected to the system. The wierd thing is that I uploaded this config. straight from the PLC and when I try to download it back again I get that error.
Any help appretiated.
I have a S7400 414-2 DP fw5.3 with a CP443 6GK443-1EX30 fw3.0 and FM350-2 on profinet The interface module is a 6ES7153-4BA00 fw 4.0 (ET200M...
1,917
I am using FM350-1 with S7 315-2DP. I use the counter module to count the encoder pulses and cut a crossing plate on the desired position. I do...
1,743
I am trying to replace an old Relience system with S7-300. The system has an encoder that uses external 220V supply and has 12V A,A*,B,B*. As...
1,150
For a revamp we will have a configuration with S7 1500 and FM350 in ET200M on profinet. Will the FM350 work? Because I see in Siemens Tia...
2,752
Dear All, Hw config. are 317-dp cpu with FM350-2 counter modle. Connect HTL encoder A to FM module nr 5 and B to Number 8. (mean channel 1)...
1,853
