FM354 User DB
Jirrr
Jan 2009
Czech
167
Hello,
We have bought older machine,made before 2001,without original program...
So I uploaded program from CPU and there are 2 FM354 for two servos,I need make servos to work,I found out manuals for FM but User DB in manual and in Program are different (FC seems also different)...so I presume it is some older version...Is there anyone who can give me some info about this older version..
most of all I need to known structure of User DB (UDT)..
Thanks a lot.....
I have replaced an FM354 card (6ES7 354-1AH01-8BG0) in an S7-300 application and now the machine does not synchronize, the drive fails because the...
1,022
I have a problem with an FM354 Servo module. There Diag light is on as well as the SF light. I can see the module in Accessible nodes but when I...
1,662
Hi, What if the FM alarm shows 0341 and 0342? Can you attack the problem exactly whether in drive / FM354 / Motor / encoder? How does the loop...
1,772
Hi, The hardware is: Click Plc model # CO-O1DD1-O HMI model # S3ML-R magnetic-inductive flow meter model # FMM100-1001. I will set the flow meter...
177
Hi guys! I'm working in Studio 5000 and have a bunch of armorstarts there (+- 40). I need to set up parameters for each of them, mostly just same...
101
