FT Activation Manager - End User File
WillM
Mar 2015
England
46
I've tried Tech Connect and Rockwell's forums with very little joy 🤾
We're currently migrating our local Rockwell licenses to a license server and I'm trying to set up the end options file. The two features I need is to limit the borrow time and force return floating licenses under inactivity.
I've currently got the Maximum Borrow feature to work using the following...
MAX_BORROW_HOURS RS5K_600.EXE:VENDOR_STRING=XXXXXXXX 12
But I cant get the Time Out feature to work....
TIMEOUT RS5K_600.EXE:VENDOR_STRING=XXXXXXXXXX 3600
I was initially trying 120 seconds in testing with no joy and Tech Connect advised upping that to an hour, but still the floating license does't return. Does anyone have any advice on this? I've followed "35376" in the knowledge base and used the "flexnet_licensing_end_user_guide.pdf".
Many thanks,
Will.
Hi Folks, who know why after start FactoryTalk activation manager V4.03, click "Get New Activations", it displays Is not I appreciate with any...
65
Rockwell Tech Support seemed to have hit a wall with this question. Already updated the version to 5.00.13 per their suggestio but am still...
233
Hello guys, I would need some help. I have installed the aveva plant scada and want to run a project. From the configurator, all are fine, as I...
111
Hello all, I have the misfortune of needing to support some old firmware version 1756 controllogix machines in rslogix 5000, as well as some...
970
Hi I have a licence for RSLinx Classic Gateway, and the version id for 4.21.00. The licence has been put on the server using FT Activation...
859
