FT View ME Startup on Boot
Bbarnett
Jul 2013
United States
77
I have a standalone ME station on a windows 7 panel. I'd like to start my application on startup without the operator being able to access windows.
I messed around with the the registry. I changed the shell to start up MERuntime.exe instead of explorer.exe but it doesn't directly open up the application (makes sense..) My question is: What file/exe is FT View ME looking for to load the application on startup? Unless there's a better way of going about this.. such as locking explorer.exe after it boots.
I guess let me restate my question:
An application for RSView32 has extension .rsv
What extension does an FTView application have? And where would this be located?
ME runs the ME runtime file. It has an extension of .mer.
Create a shortcut with the following: "C:\Program Files (x86)\Rockwell Software\RSView Enterprise\MERuntime.exe" "C:\Users\Public\Documents\RSView Enterprise\ME\Runtime\FILENAME.mer" /r /d. Place this in your startup folder.
For restricting access, try DeskLock. It's installed with the Studio stuff.
Just noticed your edit. I've been playing with DeskLock.. For some reason I can directly edit the shell in the registry but I don't have administrative rights to do the same thing from DeskLock.
Oh! Just got it, thanks Jkerekes. I needed to right click and run application as administrator. I should be able to get something working now.
Hello all, I copied the MER file from one PanelView Plus 600 to another one, using a USB drive. On the new HMI, I copied the MER file to the...
637
Hello, I am dealing with a AB PanelView 5510 device which needs to be accessible via VNC (local only, NO internet access!). To enable the VNC...
2,058
After welding near a machine, the PanelView Plus 1000 now boots into Windows rather than FactoryTalk ME, does anyone know how I can fix it? It had...
2,153
Hello I have a Panelview Plus on a site. I have copied my application from USB stick onto Internal Storage and then loaded the application all...
5,669
Hi i have an Panel View 900 screen 2711-K9C8L1 , Firmware 4.00 After power ON the only thing i can see is a sharp white screen (seems like the...
2,687
